da_zing_man opened this issue on Feb 04, 2002 ยท 13 posts
da_zing_man posted Mon, 04 February 2002 at 3:08 PM
i REALLY need someone to tell me how to change the color of the wireframes in poser, i've done it once (i think) by accident, and don't remember how i did it can someone PLEASE help! i need to know this for certain renders i'm planning, and the sooner someone helps me, the better
Little_Dragon posted Mon, 04 February 2002 at 3:17 PM
See those little color dots on the bottom right-hand side of your document window? Not the UI dots, but the ones directly underneath the Ground Shadow, Tracking, and Depth Cue buttons. Play with those (especially Foreground Color).
da_zing_man posted Mon, 04 February 2002 at 3:52 PM
i've tryed those, it works with the hidden line thing but doesn't do a thing to the wireframe one
Little_Dragon posted Mon, 04 February 2002 at 4:20 PM
Odd, it works in Wireframe on mine (and Silhouette, and Outline, and Hidden Line).
It doesn't seem to work on Lit Wireframe, though. That one uses the material colors of the model, which can be changed from the Surface Materials panel in the Render menu.
da_zing_man posted Mon, 04 February 2002 at 4:38 PM
really? crap..... it's moments like these i absolutely dispise poser... oh well, i'll keep playing with it if anyone else has some ideas, please! by all means speak up!
Bongo posted Mon, 04 February 2002 at 9:14 PM
use the paint bucket on the tools menu
Little_Dragon posted Mon, 04 February 2002 at 9:34 PM
I've just returned from a jaunt through the archives. Apparently, someone had a similar problem. Only the hidden line mode worked ... and installing the patch solved it.
Hie thee hence to Curious Labs and download the v4.03 update, if you haven't done so already.
Silvermermaid posted Mon, 04 February 2002 at 9:35 PM
Yep, just use the paintbucket tool and click on the mesh and hold, a palette should come up so you can pick a color.
shadowcat posted Mon, 04 February 2002 at 10:07 PM
I thought that the mesh took on the same color as the materials "object color"
Little_Dragon posted Mon, 04 February 2002 at 10:10 PM
Only in Lit Wireframe mode.
shadowcat posted Mon, 04 February 2002 at 10:32 PM
Oooooooh..........
da_zing_man posted Tue, 05 February 2002 at 1:16 AM
wait.... theres a patch??? HAHAHAHAHAAA!! now i feel like an idiot ^__^; thanx for the info, i'll go download right away
da_zing_man posted Tue, 05 February 2002 at 3:30 AM
SWEET!! IT WORKS NOW!!!! ^___^!!! i can't thank you enough! now i can finaly get serious with mobius renders!
