Forum: Vue
Subject: Small problem with Vue 4.05
Jcleaver opened this issue on Feb 10, 2002 ยท 7 posts
Jcleaver posted Sun, 10 February 2002 at 9:18 AM
I am having a small problem when rendering a scene with broadcast or ultra. In the image, there is a car in the first intersection. If you look closely, you can see it looks like is has exploded into a million parts! I'll post what the pic should look like in the next message.
Jcleaver posted Sun, 10 February 2002 at 9:20 AM
OK, here is what the pic should look like. This was rendered with the Final setting. Nothing else was changed between the two pics. I am wondering what happened?
Cheers posted Sun, 10 February 2002 at 9:43 AM
I have a sneaky suspicion that you may have motion blur activated for that car object, seeing that you only have it happening with the higher render settings. If you open up Mover and look at the time line, you will probably see that the car object has animation assigned to it. It certainly looks like a motion blur effect to me, but you can never tell with the way Vue has been acting lately ;) Hope that helps, Martin
Twitter: Follow @the3dscene
MikeJ posted Sun, 10 February 2002 at 11:12 AM
That might be a pretty good guess there Martin. Why? Have you seen this happen before? It almost looks like only the blur was rendered, if that is the case. Otherwise, I wouldn't have the slightest idea what could cause this, and have never once had anything like this happen.
Jcleaver posted Sun, 10 February 2002 at 11:35 AM
You hit the nail on the head Martin. I checked the animation settings and saw it was animated. I unanimated it and all is well. Thanks! John
Cheers posted Sun, 10 February 2002 at 1:28 PM
Glad I could help John :D You know how the Mover wizard is Mike ;) If you hit the Mover button by mistake, you seem to spend all your time un-animating objects, and then wishing that the timeline did not keep popping up at every oppertunity, like a determined pop-up advert LOL! Martin
MikeJ posted Sun, 10 February 2002 at 1:54 PM
Ahhh, yes... I try to stay far away from that button. ;)
