SPACEY opened this issue on Feb 10, 2002 ยท 2 posts
SPACEY posted Sun, 10 February 2002 at 12:18 PM
Is there a function in actions or automate batch in Photoshop that allows you to repeatedly offset or animate a single layer over and over using one image infinitely or finitely saving numbered files for the frames?
Must've slipped my mind...but it's the thought that counts...
http//www.wholebitmedia.com
dreamer101 posted Sun, 10 February 2002 at 2:11 PM
If you have Adobe Photoshop 5.5 or 6 then you have Image Ready. It has an animation palette. You use the Tween command to automatically add or modify a series of frames between two existing frames--varying the layer attributes (position, opacity, or effect parameters) evenly between the new frames to create the appearance of movement.
