webraiders opened this issue on Feb 11, 2002 ยท 4 posts
webraiders posted Mon, 11 February 2002 at 3:11 PM
aleks posted Mon, 11 February 2002 at 3:19 PM
delete the *.rsr from geometries folder that goes with the *.obj for your figure. it gets corrupted sometimes. i assume that you are not using propack?
PhilC posted Mon, 11 February 2002 at 3:25 PM
Check that your new OBJ actually has a group called "neck". My favorite typo in UVMapper is to make a selection then instead of going to Assign to Material I erroneously select Assign to Group. My guess is that you have assigned the neck to a group called "skin".
hauksdottir posted Mon, 11 February 2002 at 7:26 PM
Boy, is there going to be one surprised vampire when he sinks his teeth into... emptiness? ::tee-hee:: Not having a neck to stick out might save this lady some grief over the long run. All kidding aside, after you check to make sure that you do have a group called "neck", make sure that it is visible. Carolly
