Berendson opened this issue on Feb 11, 2002 ยท 3 posts
Berendson posted Mon, 11 February 2002 at 11:15 PM
I recently downloaded a file containing file in the 3d format and I am confused where to put it! I try to use it as a prop but it didn't work please I need help.
dewo posted Mon, 11 February 2002 at 11:48 PM
Go to: Import - 3ds This imports the file into your poser-window. The you can save it as a prop.
triceratops2001 posted Tue, 12 February 2002 at 9:50 AM
3d files , you better find out what kind of 3d files your format is, 3DS , OBJ, or others. if you want to import to poser, make sure it is one of the formats that supported. And if you just import the mesh into poser, it will only let you rotate, or move in XYZ directions.
