Subject: Help with Clothing Items from As Shanim
RedRowan opened this issue on Feb 17, 2002 ยท 8 posts
RedRowan posted Sun, 17 February 2002 at 1:37 PM
I have a number of items both free and purchased but seem to be having problems getting them to conform to Vickie. Do I need to change Vickie's body shape to get them to fit or do I simply need to scale the individual items? Thanks in advance HJ
Boytronic posted Sun, 17 February 2002 at 1:59 PM
you just need to scale those items to fit the body and after this just change the parent to whatever they going. If you are using the hip clothes change the parents to the bodypart hip and everything will be fine :))
igohigh posted Sun, 17 February 2002 at 2:01 PM
I too had difficulties trying to fit them to Eve4 (a task in itself) but then I started finding all the morphs she has packed into them. There is a morph for just about any shape, size, direction, or alternation one can need! Just select the different parts and scope out the dials. Still having a little trouble with the Z-axis however where Eve4 is conserned but I should have Vicky soon. (don't worry Eve, you Will Not be shelved;-)
Cin- posted Sun, 17 February 2002 at 2:01 PM
I know in the string cloth readme file there are instructions for fitting it to Vicky... the other clothing items I've done a combination of scaling the clothing and victoria to get it to fit... some involve more work than others...
RedRowan posted Sun, 17 February 2002 at 2:08 PM
Cheers for all the help, guess I'm gonna have to spend a little more time playing around with the settings :)
whoopdat posted Sun, 17 February 2002 at 2:16 PM
Yeah, with a little work you'll be able to go get most of it to fit. The only thing I had problems with was the hip cloth 2 (updated version), and I couldn't get that to go. I used the old one instead and it fit right after only a few changes, whereas the updated one I couldn't get to fit without it being huge in some areas and small in others. That aside, everything else I've used has worked out very well. It's very good clothing.
thgeisel posted Sun, 17 February 2002 at 2:29 PM
I bought the masabody here , and the figuresize was set to "modell" i set it to " Adult" than it fit perfect. I like the things they make,
steve-law posted Thu, 03 October 2002 at 6:15 PM
I've just downloaded these and I can't get them to fit properly even scaled - the hip cloths in particular are either too big ont he z or the hip bone pokes through on one or both sides. (And I can't see any morph dials at all?) Does anyone have a modified version that works on Victoria? (Assuming permission to distribute of course)
