Forum: Carrara
Subject: Carrara full texture mode did not work!
Spike opened this issue on Jan 07, 2000 ยท 5 posts
Spike posted Fri, 07 January 2000 at 12:50 PM
I had my carrara set to direct x render preview and I never got the full texture mode to come up. it was the same as full shaded. I just changed it lastnight to Software render and now I get full texture previews at 40 fps. COOL!!!! There was a note on the onelist about using software render. I would suggest that you set it to software render if it is not. Like I said, I am getting 40 fps in texture mode and this Kicks butt!! "Makes ya want to get up and beg for buttermilk". Spike
You can't call it work if you love it... Zen Tambour
Felderin posted Fri, 07 January 2000 at 12:55 PM
How exactly do you change Carrara from OpenGL/D3D to software mode? Am I totally missing something? I am still in the process of RTFM-ing, so that is certainly a possibility, I guess... =)
Spike posted Fri, 07 January 2000 at 1:04 PM
at the bottom right of your screen there are some balls to set your preview level. The first one is a up arrow. select it. from there it's straight forward. Spike
Felderin posted Fri, 07 January 2000 at 2:07 PM
Ahhhh.... it all becomes clear to me now. =) Thanks, Spike!
Hob posted Thu, 13 January 2000 at 7:32 PM
That's it! Play with your............, err, nevermind. Sorry, (REEEAAALLY) BAD JOKE.
