kruzr opened this issue on Feb 18, 2002 ยท 8 posts
kruzr posted Mon, 18 February 2002 at 9:13 PM
zoon posted Tue, 19 February 2002 at 3:17 AM
I just did a quick test using 4.05-02 and a cob file from MetasequoiaLE in win 98se, and it loaded fine. Are other object formats ok on your machine? Let e-on know about the problem, its probably not just you.
gebe posted Tue, 19 February 2002 at 3:32 AM
I could not import a cob from MetasequoiaLE and got the same message as Mark (Win 98). Guitta
MikeJ posted Tue, 19 February 2002 at 8:12 AM
I think it's the same thing like with the Lightwave .lwo situation: .LWO objects will load if they were made with a version of LightWave 5.6 or earlier. The Lightwave people changed the format as of version 6.0. Vue will import .LWO files created no later than LW 5.6. I think that's the case for True Space as well: The ones which aren't importing are likely newer versions of the .COB format. Strangely enough, 3D Exploration can read all these files just fine, and it's current version is younger than Vue 4....
Myske posted Tue, 19 February 2002 at 10:18 AM
I got the same mess also. But only whwn using the blob function in MetasequoiaLE If I only work with primitives it works fine. ???? Myske
gebe posted Tue, 19 February 2002 at 10:21 AM
For me it works now also. It did not work with an imported Poser figure which I have then sved as a cob. Guitta
kruzr posted Tue, 19 February 2002 at 10:37 AM
I just gave some more import file types a try in Vue, & at this time it seems the only file that I can't import is .COB. All the rest imported / excepted a texture or material / & rendered fine. I suppose I can always convert the .COB file to another file type, then import it into Vue 4.05-02. . . ;^) Mark.
Kattleprod posted Wed, 20 February 2002 at 4:22 AM
I've never had much success importing trueSpace files - the Vue manual does state that it will import trueSpace 2 files - I use 4.3 so I just figured it was stumbling over the newer features. Saving my trueSpace models as 3DS from trueSpace usually did the trick.
