CryptoPooka opened this issue on Feb 20, 2002 ยท 15 posts
CryptoPooka posted Wed, 20 February 2002 at 2:28 PM
lalverson posted Wed, 20 February 2002 at 2:50 PM
Since they are all seperate parts . I would use the material editor the dotted sqare with a dot in it on your poser interface and then select each part and assign material then just give each part and new mat name (Mic,stem,housing,battery,ect) then close that window and then re-assign the textures to there parts. then export, and making sure you keep existing groups and maerials. then once saved you can import that new obj. when it loads it shoudl have the correct textures still just the wrong size. all you will need to do then is scale it. and save it as a prop. i would also save the pz3 just in case. then do a new document and bring the prop in from the prop library you saved it in and then a model and then parent it to the modle then save again under a different name . poser will ask if you want it to be a smart prop say yes and viola! a dumb prop and a smart prop,
CryptoPooka posted Wed, 20 February 2002 at 2:56 PM
Ooo! Got it! Thank you!
CryptoPooka posted Wed, 20 February 2002 at 3:36 PM
All right, when I export and them reimport it, all of the transparencies are getting lost, and none of the bump maps are transferring. Am I doing something wrong, or do I need to readd them, try to export again, or just wait until I save the blasted thing as a smart prop in a PP2?
lalverson posted Wed, 20 February 2002 at 4:12 PM
no you'll have to re-apply all the textures and bumps and set the materials back to what they were origianlly. since there is a limit in what info gets tranfered to the export obj
CryptoPooka posted Wed, 20 February 2002 at 4:26 PM
lalverson posted Wed, 20 February 2002 at 4:45 PM
I could use them.
jaybutton posted Wed, 20 February 2002 at 6:13 PM
Sure, they would be great! Jay
CryptoPooka posted Wed, 20 February 2002 at 6:56 PM
Ajax posted Wed, 20 February 2002 at 7:39 PM
Looks cool, I can use that. Did you think of making the mic arm bent instead of straight? So it curves in toward the mouth a little?
View Ajax's Gallery - View
Ajax's Freestuff - View
Ajax's Store -
Send Ajax a message
CryptoPooka posted Wed, 20 February 2002 at 7:54 PM
VirtualSite posted Wed, 20 February 2002 at 7:58 PM
Crypto, I'll d/l it tonight and work with it on my Mac for you. It's a great looking piece, BTW.
CryptoPooka posted Wed, 20 February 2002 at 8:01 PM
Great, VS, please let me know. I honestly have no idea how files crossover for Poser between PC and Mac, and none of my buddies with Macs use Poser so I'm stuck between a rock and an apple place.
VirtualSite posted Wed, 20 February 2002 at 8:01 PM
Crypto, we have a problem. When I try to d/l, it goes to about 36k and stops dead in its track. Just a heads up.
CryptoPooka posted Wed, 20 February 2002 at 8:08 PM
Urg. Keeping an eye on that now. I'm not having any trouble, and neither are the other two I sent to try to grab it. Dunno if it's a firewall problem, or a download limiter or what. Hrm. If anyone else has any problems getting the file, please let me know.
