Tomsde opened this issue on Feb 21, 2002 ยท 7 posts
Tomsde posted Thu, 21 February 2002 at 10:04 AM
I've recently bought UV Mapper Pro and was trying to load a preview of a high res texture map via actions into UV mapper and it didn't work. Upon further investigation I discovered that my Window's clipboard was saying that the image was too large for it. If I cut the resolution in half it will load the image with no problem, I started with a 1400 x 1400 canvas. I have over 500 megs of RD ram memory on my system, so it can't be that I'm out of ram. Has anyone else had a similar experience? If so is there a work around?
the3dwizard posted Thu, 21 February 2002 at 10:19 AM
You might write Steve to see if he has had the problems before. I am sure he will be glad to help.
SAMS3D posted Thu, 21 February 2002 at 10:20 AM
No, mine works great, get in touch with Steve right away, he will fix what ever problems you are having. Sharen
Tomsde posted Thu, 21 February 2002 at 11:34 AM
I did write to Steve, he said that he wasn't aware of anyone else having the problem. He was very nice. I just wanted to see if anyone else out there had the same thing happening and what they are doing about it. It looks like I can manually load the maps and have it open at the same time as Photoshop, but that would require saving in bitmap format before I could see a preview.
SAMS3D posted Thu, 21 February 2002 at 12:11 PM
Yes, that is correct, I save in bitmap format then open it again in my paint program. Also, what you can do to open other maps, is just change them into bitmaps and it will see them. Sharen
atom123 posted Thu, 21 February 2002 at 7:22 PM
Attached Link: http://www.geocities.com/lithunwrap/
i hope steve doesnt shoot me but...... ive started 2 use lithunwrap. it gives better control over the template and the "pieces" (you can move them around w/ no prob) it takes many different formats and the best part is its free... lol, i been posting this link everywhere.Tomsde posted Fri, 22 February 2002 at 9:45 AM
Thanks perhaps I should give it a whirl as well.
