Krel opened this issue on Jan 10, 2000 ยท 4 posts
Krel posted Mon, 10 January 2000 at 3:17 PM
I'm a VERY casual user of Bryce. I need to export objects created there, i.e. a rock or simple geometric shape. The Export Object option on the file menu is always disabled. Is there a way to export objects? Do I need some sort of plugin? This is for Bryce 4......... Thanks, Krel
adam posted Mon, 10 January 2000 at 4:27 PM
Sorry Krel!! There is no way to export an object in Bryce, only in obp format. If that is what you want to do, then place the object you want to export into the create section (click the arrow next to create). Then push add at the bottom left corner to add it to the user section (or any section you want). After the object pops up in one of the boxes, highlight it and push export (on the bottom as well). Now you have your object in obp format. Hopefully Bryce 5 will be able to export objects in different formats. -Adam
adam posted Mon, 10 January 2000 at 4:29 PM
Oh, forgot to tell you... you can export terrains as a different format, but thats it.
Krel posted Tue, 11 January 2000 at 11:41 AM
Thanks.....guess I'll have to wait..... Krel
