Forum: Photoshop
Subject: does annyone know?
mangina opened this issue on Feb 24, 2002 ยท 6 posts
mangina posted Sun, 24 February 2002 at 11:15 PM
I would like to know where i can download some new brushes. If annyone knows . I would appreciate it . Thanks
dreamer101 posted Mon, 25 February 2002 at 1:25 AM
Just a few:
fur and hair
miscellaneous
stars and textures
Don't forget to append some of the existing brushes in your folder that aren't being shown. Only one set shows as default. You can also make any design any brush you want. Create an image. Edit - Define Brush.
BazC posted Mon, 25 February 2002 at 5:45 AM
You have to make a rectangular selection around the pattern before you hit 'Define Brush' don't you? Baz
mangina posted Mon, 25 February 2002 at 10:05 AM
Thanks Dreamer. And BAZ i will give those a try . Oh and i already have all the extra brushes loaded as well / ;-)I just wanted somethinf new . And now i can try to make then too ;-).
dreamer101 posted Mon, 25 February 2002 at 11:48 AM
Define Brush will work with a selection or without. It trims it down to the image size. If you want a selection of only part of image, then you need a selection. It doesn't seem to accept a selection larger than image (to include area around image).
With Define Pattern you can make a selection. If you don't make a selection, it will select the whole canvas area.
mangina posted Tue, 26 February 2002 at 10:27 PM
cool thanks for the helpful info dreamer ;-)
