wimvdb opened this issue on Jan 11, 2000 ยท 2 posts
wimvdb posted Tue, 11 January 2000 at 5:18 PM
I have donwloaded a building from 3dcafe and try to use Bryce materials on the walls. If I do this (for instance bricks) the materials are extremely stretched. I have experimented by changing the mapping mode to all possible values, but none seem to work. As far as I can figure out, the problem seems to be that the wall is a set of polygons and not a (bryce) cube. Fiddling in the material editor with streching or sizing does not seem to work either. Could anyone give me a hint an how to do this? Thanks in advance, Wim
Spike posted Tue, 11 January 2000 at 5:40 PM
The x,y,z scale should do the trick for you. before you change the x,y,z scale look at it and note it's values if you see values like 10.2 and fractions, a small change will make a big difference. Spike
You can't call it work if you love
it... Zen
Tambour
