Subject: help, Headache!
triceratops2001 opened this issue on Feb 26, 2002 ยท 4 posts
triceratops2001 posted Tue, 26 February 2002 at 11:41 PM
I have downloaded a model for P4 female, thats the one on the left.
I like her perfect face, and I hope she can have better movement so copied the morph on the head to an eve (forgot eve3 or eve 4).
Then I found that the head wasembed into the neck on eve body. That was cause by a morph. The morph shorten the part of the head which connected to neck, and this morph will lower the head to make the neck will not look too long.
So, if I do not use the morph, her neck will be too long.
And using the morph, the head will embedded into the neck.
Ive try the hiddendial about the y offset, but it cant fix the problem, anyone can help me?
Thanks!
JeffH posted Wed, 27 February 2002 at 12:45 AM
Maybe there is a neck morph that needs to be tranferred as well?
triceratops2001 posted Wed, 27 February 2002 at 1:00 AM
I can't find a morph on the neck involved in this. Also , the neck of P4 female and eve has different shape, may be different number of vertex, I don't know the morph can tranfer or not. any other idea?
Momcat posted Wed, 27 February 2002 at 7:12 AM
The worst that can happen is it doesn't work. It can't hurt to try. Try exporting the neck as a MT and applying it to Eve. If that doesn't work, you may have to do some magnet work on the neck. You might also try emailing Yamato for input on this. S/He might have an idea or two if the necks are not compatable. I also know that Masa has done a lot of morph conversions for Eve, so he might be able to help as well.
