fls13 opened this issue on Mar 04, 2002 ยท 5 posts
fls13 posted Mon, 04 March 2002 at 2:10 PM
I'm still having trouble keeping my meshes from spliting after boning and grouping. I am using the weld group tool. Any suggestions?
wolf359 posted Mon, 04 March 2002 at 2:19 PM
Little_Dragon posted Mon, 04 March 2002 at 4:23 PM
I recently realized that part of my splitting problem was being caused by the layout of the groups themselves. Ideally, the edges of one group should touch only one other group. If the edge touches two or more groups, splitting will occur.
That probably isn't a concise explaination of the situation, but it is difficult to explain without illustrations.
Autogroup is great at doing most of the gruntwork, but I have to go in manually and fine-tune the groups.
the3dwizard posted Mon, 04 March 2002 at 5:42 PM
fls13, show us a picture. It is worth a 1,000 words you know :)
fls13 posted Mon, 04 March 2002 at 9:43 PM
Of course I'm using auto group. That's the wonder of Poser, isn't it. The app does all the grunt work for you, right? But even when I go back and adjust the groups, I'm still getting the same problem, except the break takes place where the new break is. One thing I've noticed is that you can't tell where the vertices are in Poser, which I'm not used to. It makes grouping a lot easier. Also, in other apps, it's a good idea to have vertices near joints in groups on both sides of the joint. In poser, you apparently can't do that.
