Kingfisher opened this issue on Mar 05, 2002 ยท 5 posts
Kingfisher posted Tue, 05 March 2002 at 11:11 AM
Im using Bryce 3D. I
m having problems with motion path & the align tool. When used it aligns the object to the path but the object is facing the wrong way. How can I get round this to get it to work correctly. I`ve been through the manual but cannot suss out what to do.
GROINGRINDER posted Tue, 05 March 2002 at 1:50 PM
Can't the rotational settings in the object attributes box or the edit pallett tools be used to turn it back around.
rubycon posted Tue, 05 March 2002 at 3:39 PM
I think that Bryce aligns the object's Z-axis along the path. Your object apparently has the Z axis facing the wrong way.
Don't worry. You just need to use a null object. Create a cube and position it so that it's Z-axis is aligned along the path. Link it to the path. Now link your model to the cube. When you move the cube along the path, the model will go along for the ride. (remember to shrink the cube down so that it's hidden inside your model.)
Rubycon
Kingfisher posted Wed, 06 March 2002 at 1:15 PM
Thanks for the info. Rubycon. Works ok. Although taking further what you said about the Z axis Ive rotate the objects out of Bryce & resave them & when reloaded they work fine with the align tool. Its a poser .obj I
ve loaded into Bryce & I know what its like with poser & its axis/scale settings. Thanks again Kingfisher
GROINGRINDER posted Thu, 07 March 2002 at 1:23 AM
Hey Kingfisher that's a great fix. I like yours too rubycon.
