Subject: A Problem With morphs
pimpinwillye opened this issue on Mar 06, 2002 ยท 3 posts
pimpinwillye posted Wed, 06 March 2002 at 1:44 AM
Attached Link: I don't suffer from insanity, I enjoy every minute of it!!!
I created a morph for mikes entire upper torso with magnets and then exported as an obj with the As Morph box ticked and poser spat it when i tried to load it. If Anyone can help it would be appreciated Thanx In Advance Check out my site as well! (Pleez)
HandspanStudios posted Wed, 06 March 2002 at 2:14 AM
You have to export the morph for each body part and then apply to each body part. So in other words you cannot combine abdomen and chest in your export because then they won't load properly. So if you made a torso morph which included both the abdomen and chest you would export each part seperately.
"Your work is to keep cranking the flywheel that turns the gears that spin the belt in the engine of belief that keeps you and your desk in midair."
Annie Dillard
pimpinwillye posted Wed, 06 March 2002 at 4:10 AM
I did that but still none of them worked
