Subject: more Max morph problems
AliasAngel opened this issue on Mar 08, 2002 ยท 2 posts
AliasAngel posted Fri, 08 March 2002 at 7:30 PM
When I import my object into 3DS Max, it's too small to see and it won't let me zoom in on it. Anybody know how to fix this problem?
rodzilla posted Fri, 08 March 2002 at 7:47 PM
i assume you're using the habware obj2max,max2obj plugins?if not get them,if you already have them change the vertex scale parameter on the plugin dialog...put it at 100 when you import,don't forget to decrease the scale when you export! set the output plugs vertex scale to 0.01 and all should be well
