Barbarellany opened this issue on Mar 09, 2002 ยท 4 posts
Barbarellany posted Sat, 09 March 2002 at 4:09 PM
Attached Link: http://www.renderosity.com/viewed.ez?galleryid=152320
If you have time please check out my texture. I am having eyebrow problems even after trying the usual tricks. I would also like any other comments that will help make her the beauty I know she is. Thanks, BarbaraGhostofmacbeth posted Sat, 09 March 2002 at 4:30 PM
It looks like the eyebrow is reddish rather than the same color as the "skin head" material .. to make them the same they need to both be white or tan or wahtever the base is
TygerCub posted Sat, 09 March 2002 at 5:09 PM
Also check your Highlight or Ambient color. They will also make a difference in the appearance if they are not set to the same colors as your "head material"
Barbarellany posted Sat, 09 March 2002 at 5:28 PM
The reddish color is common to the entire head and body and I have all colors set the same on the head. It seems when I tried the "set trans max and min to 100 solution that the black disappeared along with the golden glow. With the settings at 0 it is the same black but no golden glow that is resident to the texture mape and apparent everywhere else.
