Subject: Uploading problem
Kathleen opened this issue on Jan 15, 2000 ยท 5 posts
Kathleen posted Sat, 15 January 2000 at 11:03 PM
Thank you to everyone who told silly lil' me why my clothes files weren't working. You were right. And they work perfectly now. ;) But, it seems I went from one problem to the next. I have some textures and bump maps that are supposed to be used for certain clothing. Problem being, I can load the texture, but when I try to load the the bump map, or a transparency map, it won't do it. I can pick the bump map, and press the "load" button, and it looks like it's doing it, but when it's all done, it hasn't been loaded. It doesn't even give me a pop up warning, or anything. It just won't upload it. It also won't upload a second texture file if I want to. It's like it can only load one thing, and then it's done for the night. Now I know there's gotta be a reason for it, and I don't see what I can be doing wrong. If someone else has gone through this, can you please explain how to fix it? I'd really appreciate the help. -Kathleen
JeffH posted Sun, 16 January 2000 at 4:13 AM
I've never seen this, what format are the files?
kristyn posted Sun, 16 January 2000 at 11:26 AM
the only time I had this problem is when the pictures are too large for Poser. Check the image information and if you can reduce the image size without sacrificing quality, then do it. kristyn
Kathleen posted Sun, 16 January 2000 at 12:23 PM
The file formats I'm using are tif and pict. Normal formats. You may be right, Kristyn. Guess I'll just have to try that out and see if it works. -Kathleen
skee posted Sun, 16 January 2000 at 9:45 PM
I also have had this problem, I found out if you do a control -alt -delete to end task and then hit cancel, it will reopen that file and then let you bring in the texture you opened.... works for me. skee
NOTE: No trees were killed in the sending of this message, but a large
number of electrons were terribly inconvenienced.
