romanichel opened this issue on Mar 11, 2002 ยท 2 posts
romanichel posted Mon, 11 March 2002 at 10:08 AM
For use null figure I must change the names of actor group instance, how it is wrote below: ------------------------------------------ In order for this to function properly, the desired figure's cr2 must first be prepped. That is... all actor/group instances must be ":1" and the figure's name must be "Figure 1". If actor/group instances are not ":1", you can do a global replace of whatever they are (:2, :3, :4.... etc.) with ":1". Such is also the case for the "Millennium Null". ----------------------------------------------- anyone could explaine me how I can make global change?
Kelderek posted Mon, 11 March 2002 at 10:56 AM
You should be able to do it in any text editing software. Do a "replace" to change all instances of the text string :2 (or whatever) to :1 in the cr2-file concerned. However, if you are using the null loader with a standard Victoria 2.0 cr2, this is not needed, all actor instances should be :1 as default. Worked for me without changing anything.
