Forum: Bryce
Subject: Warp engine glow
osiris9 opened this issue on Mar 13, 2002 ยท 4 posts
osiris9 posted Wed, 13 March 2002 at 11:29 AM
I have made many starships with warp nacelles but so far I have been unable to create a good glow for the engines is there a good tutorial on how to make glowing textures or could someone advise me on how to get my nacelles glowing?
Aldaron posted Wed, 13 March 2002 at 12:27 PM
If you look in my "Sun Glare test" post you'll see Voyager with the nacelles glowing. If you wish to acheive that effect select the object that represents the glow and change the material to volume and 100% ambience, select what color you wish it to be. If you want it to cast light you'll have to add a light in there, it should work.
Allen9 posted Wed, 13 March 2002 at 4:03 PM
For it to work best, you also need to go into the material and turn OFF the "cast shadow, recieve shadow, and self-shadow" options in the material. Glowing things with shadows across them just do NOT look right. It's really important to do this with the material on any object that is supposed to be giving off light, such as flames, etc. In addition to the material looking more realistic, if you then stick a light source inside it, the light can radiate outward unobstructed.
osiris9 posted Wed, 13 March 2002 at 11:33 PM
Thank you very much for your advise it has helped me alot thanks.
