Subject: RSR converter and photoshop question
shredboy opened this issue on Mar 13, 2002 ยท 11 posts
shredboy posted Wed, 13 March 2002 at 5:37 PM
I just started using RSR converter to make some pics for MAT files but I can't figure out how to invert the alpha channel with Photoshop 6.I feel pretty stupid as I use PS all the time but this one escapes me.Has anyone done this yet?Thanks in advance for any help,Shredboy
Staby posted Wed, 13 March 2002 at 5:44 PM
When you are in the channel palette and have the alpha channel selected press Ctrl+I. This should work.
shredboy posted Wed, 13 March 2002 at 5:51 PM
Thanks!I never use any palette's except the layers,I would have never found it!
Barbarellany posted Wed, 13 March 2002 at 8:00 PM
To feel even more dumb, how do you get to the alpha channel to choose it?
lhiannan posted Wed, 13 March 2002 at 8:54 PM
In the Layers window, (assuming you have a psd with alpha channel such as Poser will automatically supply or some similar type of image), select the Channels tab and scroll down.
herr67 posted Wed, 13 March 2002 at 9:45 PM
Do you need to invert the alpha channel? I have some old programs that do not work in layers and I was able to convert most of my files (95%) without doing anything but resizing them. The other 5% I reduced the colors which sometimes worked. Either way I was able to converted all my picts.
Barbarellany posted Wed, 13 March 2002 at 10:51 PM
so there is no alpha channel if you are making say a texture from scratch? PS6 doesn't make it automatically, or it's not till you reopen it as a psd that you find it? Sorry, I was working on something one day with a tutorial and it wanted me to do something with the Alpha channel and I couldn't find it. Ony color channnels.
lmckenzie posted Thu, 14 March 2002 at 2:01 AM
I don't know if this is relevant but you have to save a Poser render in a format like TIF which supports alpha channels - JPEG doesn't.
Barbarellany posted Thu, 14 March 2002 at 2:26 AM
Thank you. Now I know why I have never found them. I use JPEG all the time cause it is so versitile.
lmckenzie posted Fri, 15 March 2002 at 1:02 AM
Yes, had the same problem myself at first. Just make sure to save your final thumbnail as a PNG file and size it to 91x91 pixels. Even one pixel off and rsr convert won't work.
