Chrisdmd opened this issue on Mar 14, 2002 ยท 11 posts
Chrisdmd posted Thu, 14 March 2002 at 6:22 PM
Chrisdmd posted Thu, 14 March 2002 at 6:24 PM
Chrisdmd posted Thu, 14 March 2002 at 6:28 PM
Chrisdmd posted Thu, 14 March 2002 at 6:31 PM
SAMS3D posted Thu, 14 March 2002 at 6:34 PM
What are you looking for, I think it all looks wonderful. Sharen
Chrisdmd posted Thu, 14 March 2002 at 6:42 PM
To create realistic glass using Vue in less time than Bryce. I guess what I'm really asking is what custom settings are people using with the glass materials because when I use the presets my results aren't living up to my expectations. Chris
MikeJ posted Thu, 14 March 2002 at 7:41 PM
You need to really mess with things such as the refraction index, and the "fade out" color and "murkiness" slider, not to mention the "turn reflective with angle" settings, all under the transparency tab in the material editor. I don't really like any of Vue's stock glass materials that much, though the refraction index settings are correct in relation to reality. Meaning, for example, typical air has a refraction index of 1.0, glass, 1.52, etc. All that can be changed though. Just play around with it all. Vue's material editor is very powerful. And you also might want to select "object Standard" for your mapping, or your materials might change as you move the objects.
YL posted Fri, 15 March 2002 at 5:36 AM
Your images are very good concerning the object rendering. What you should improve to obtain "radiosity faking" is the shadows , and the refracted light on the ground in case of glass. It is not an easy thing, but some "experimental" rules exist which have been discussed recently on this forum, like : - use soften shadows for materials, especially for the ground - use soften for the light - use a light at the opposit direction of main light, and uncheck "cause shadows" in order to soften the shadow of the object. - use noise bump at the surface of ground Lot of other tips exist, I'm a beginner in that field :) Yves
Varian posted Fri, 15 March 2002 at 2:13 PM
Looking good! I'd also recommend playing with the fade-out colors on the glass. I prefer setting the dark color to black and the light color to white. It gives a good glass look that way. Of course, if the background is either mostly black or mostly white, then a blue-gray would be preferable just to help it show up. :)
the3dgm posted Sat, 16 March 2002 at 8:53 AM
I've got a couple of questions. 1) Who's Rich and where is his dome lighting? It has to be the greatest lighting of all time to be GI and cast hard edge shadows like that. 2) Are you really talking caustics or radostiy? The general look in all four renders looks the same to me (radosity), however, the caustics are different. but then again you are using two different programs that generate materials differently, and have different render engines.
Axe555 posted Sat, 16 March 2002 at 3:22 PM
I'm Rich, but I didn't create the dome. I just got it from the freestuff here.
