SewerRat opened this issue on Jan 18, 2000 ยท 9 posts
SewerRat posted Tue, 18 January 2000 at 4:44 AM
JeffH posted Tue, 18 January 2000 at 5:58 AM
The only time I saw this happen is when there is more than one copy of the import plugin installed. Check to see if this is the case. -JH.
SewerRat posted Tue, 18 January 2000 at 6:10 AM
nope, I only appear to have one plugin SewerRat
SewerRat posted Tue, 18 January 2000 at 6:14 AM
other objects I've made I seem to be able to export/import to poser with impunity but....as soon as I import something from this model...no menu weird 'eh? could it be some polygon count thing? but that sounds wrong, this doesn't use excessive vertices SewerRat
JeffH posted Tue, 18 January 2000 at 6:16 AM
Run it through UVmapper and save it out, then see what happens. -JH.
SewerRat posted Tue, 18 January 2000 at 6:19 AM
but UVMapper only loads obj files, and max doesn't export to obj I'm using 3DS files right now SewerRat
SewerRat posted Tue, 18 January 2000 at 6:47 AM
ok...I'm not sure why this was messing up, but if I export the 3ds file into polytrans, then export as obj it imports just fine and dandy THANKS FOR YOUR HELP JEFF! SewerRat
kits posted Tue, 18 January 2000 at 5:48 PM
SeweRat if you get the max2obj plugin from habware then you can export to obj from Max Chris-S
SewerRat posted Tue, 18 January 2000 at 9:59 PM
I was looking for that, checking out www.ktx.com what is the URL for habware? www.habware.com doesn't seem to work. I also read somewhere (on a tutorial site I think) that it doesn't work 100%...but shrug I'm not going to look a gift horse in it's mouth =) Thanks! SewerRat
