Forum: Vue
Subject: vue anim help
dolly opened this issue on Mar 19, 2002 ยท 7 posts
dolly posted Tue, 19 March 2002 at 10:33 AM
Hey all I am doing a fluny anim in vue of a city of atlantis now the scene is set and it is 45 seconds long Now i am rendering the animation on another machine which is a amd athlon 1300 and 326 of ram now it has 1351 frames to render so i did a test in broadcast and when i played the anim it looed very grainey is there away of not haveing it so grainey ie do i need to compress it or something cheers dolly
dolly posted Tue, 19 March 2002 at 10:40 AM
errr it should say flyby lol
Shadex0r posted Tue, 19 March 2002 at 11:04 AM
What resolution did you render at? If you're watching it at larger then the rendered resolution it will get worse. Could it be motion blur?
dolly posted Tue, 19 March 2002 at 11:11 AM
hey there the setting was done at broadcast and it just looks grainey and that is at the 320/240 size i renderd it at
audity posted Tue, 19 March 2002 at 2:14 PM
Hi Dolly, ... it's nearly impossible to get "clean" animation with VUE :(. There is always flickering ! Even with the highest anti-aliasing quality, the results are always average. I could once create a totally clean and smooth animation. But there was only a few primitives with basic materials (no vegetation, no models, no terrains, etc...) and it took ages to render ! The only thing you can do to reduce this grainy effect : 1. Don't use soft shadows. Instead use normal lights with high fall off and gentle shadows (40%). 2. Don't use volumetric materials and lights. 3. Always use motion blur. 4. Use a very high anti-aliasing (broadcast is not enough). 6. Avoid strong exposure changes (i.e. from light to dark). 7. Avoid materials with too many different colors and elaborate bump maps. Materials with variable highlights or variable reflections should also be avoided. Try to keep it simple ! 8. Always render at full frame uncompressed. Don't use any codecs (MPEG1, Cinepack, Indeo, DivX, etc...). 9. Choose 24 frame/sec or more. 10. If you can, render at 640x480 pixels and reduce the size of the animation in a video editor (premiere, final cut, vegas video, video factory, video studio, etc...). If you don't have one, there are some free video editor available at www.download.com. This will "soften" the animation. Before launching the rendering of your "Atlantis" animation, test all the materials in a very simple animation. You will notice that some materials are more grainy than other. The atmosphere and the lights used are also important. To get acceptable animations I had to create a specific folder with "animation compatible" materials and atmospheres... Hope that this will help ! By the way, how did it go with your 360 Atlantis panorama ? Are they good, can we see them ? Eric
audity posted Tue, 19 March 2002 at 2:17 PM
I forgot n5 : 5. take it easy with the camera ! If your fly-over goes too fast, the motion blur will be very dirty. Eric
dolly posted Tue, 19 March 2002 at 2:25 PM
Hey all Thanks for the help but i sorted it lol all i forgot to do is compress the anim while rendering now i have an anim that looks as good as a still image lol cheers dolly
