Subject: Error at importing a morph target
Seravajan opened this issue on Mar 22, 2002 ยท 11 posts
Seravajan posted Fri, 22 March 2002 at 8:04 AM
I get an error if I try to import a morph target. "Target does not contain the correct number of points" or somehow like this because I own the german edition of poser. Seravajan
Valandar posted Fri, 22 March 2002 at 8:39 AM
Well, when you get that error, it means that the morph target you're trying to apply isn't based on the same geometry as the body part you're trying to morph. Can you give us more information? Such as what morph you're applying and to what body part?
Remember, kids! Napalm is Nature's Toothpaste!
Valandar posted Fri, 22 March 2002 at 8:40 AM
Oh, and what figure the morph is from, and what figure you're trying to morph?
Seravajan posted Fri, 22 March 2002 at 8:59 AM
I have exported the head as a morph target from Poser 4 Dude to experimenting with morphs. I'm using Poser 4, Scaler 3c for scaling up and 3D Canvas for working on the mesh. After finishing the work on 3d Canvas I scaled it back and then I tried to import it as a morph object. Seravajan
smallspace posted Fri, 22 March 2002 at 11:48 AM
3D Canvas probably split the head into separate objects and doubled the vertices at the points where those objects connect. The head is really composed of the teeth, the tongue, the eyelashes, the eye brows, the inside of the mouth, and the rest of the head. Truespace does the same thing and has the same problem. -SMT
I'd rather stay in my lane than lay in my stain!
Seravajan posted Fri, 22 March 2002 at 12:15 PM
Yep this is true. But how to circumvent this? Is there a possibility to prevent this by the export from Poser 4? Seravajan
Seravajan posted Fri, 22 March 2002 at 12:27 PM
Or have I to use a program to fix this? Seravajan
smallspace posted Fri, 22 March 2002 at 1:47 PM
My solution is pretty expensive, and I have no idea if it would for 3D Canvas. Polytrans from Okino Software is a format converter that's very powerful it lets me import the Wavefront OBJ file without breaking it apart then export it into Truespace's native COB file format. When I'm done, I import the file back into Polytrans and export back to OBJ. This works for Truespace because Polytrans supports the Truespace native format. I don't think it supports 3D Canvas native format, if indeed, 3D Canvas has a native format. A far less expensive but more complicated work around that a lot of people use is John Wind's "Compose" utility. It works by remembering how a mesh was broken up, and then making sure it's reassembled properly. It's not the easiest program to use, however, and I still don't know if it will help you with 3D Canvas. Compose is a Java program that will work on both PC and Mac. You'll still be working in object format, but this should work. Here's the link to download Compose: http://home.tir.com/~johnwind/Compose11.zip -SMT
Seravajan posted Fri, 22 March 2002 at 4:38 PM
I have compose but there is no help about how to use its special abilities. Seravajan
Seravajan posted Fri, 22 March 2002 at 4:48 PM
Insane up to $900 for a converting program. For this money can I get Carrara and its sister AMAPI 3D as a bundle! By the way: Can Poser export into Truespace COB format because 3D Canvas can import/export this format too. Else I have to transform it with compose and trying to import it as a truespace file. Seravajan
smallspace posted Fri, 22 March 2002 at 5:31 PM
There has been talk about a Truespace plugin for Poser Pro, but at this time Poser only exports OBJ, 3DS, LWO, and DXF, although it also has plugins for Max and Lightwave. If you're not using one of the plugins, then you have to export/import via OBJ format in order to use the mesh as a morph target. -SMT
