LeBurns opened this issue on Mar 22, 2002 ยท 11 posts
LeBurns posted Fri, 22 March 2002 at 12:09 PM
Penguinisto posted Fri, 22 March 2002 at 12:13 PM
sure - I can cook one up in less than a mintue. where d'ya want it e-mailed to? /P
Penguinisto posted Fri, 22 March 2002 at 12:15 PM
Also, do you want a 64-segment sphere (very round, but high-poly), 32-segment sphere, or 16? (I think the Poser ball is like 8 or something.) /P
LeBurns posted Fri, 22 March 2002 at 12:18 PM
Wow that would be great. The smoother the better as it is a large part of the pic. Send to gamerleburns@triad.rr.com Thanx! BTW, what are you using to make it?
Penguinisto posted Fri, 22 March 2002 at 12:23 PM
OpenFX... as soon as I can get all the normals to export, I'll have 'em cooked up. /P
Penguinisto posted Fri, 22 March 2002 at 12:32 PM
'k - check yer mail; I included two different styles, in both .obj and .3ds format. The smoothest of the two is the lat-long style ball, but boyohboy is it loaded with polys... /P
PJF posted Fri, 22 March 2002 at 12:57 PM
If you have Bryce, you could export that scene (as obj) from Poser, and then replace the Poser sphere with a Bryce example after import. Bryce spheres are absolutely perfectly round, no matter how close you get to them.
LeBurns posted Fri, 22 March 2002 at 2:31 PM
I loaded a sphere in Bryce 4, but it wouldn't give me the option to export the object. ?? I did find a nice sphere using Thorne's atmosphere tool, but I will certainly check out these others. Thank!
PJF posted Fri, 22 March 2002 at 2:39 PM
Unfortunately, you cant export any Bryce 'primitives' (box, sphere, etc). My suggestion was to export the items from Poser, replace the Poser ball with a Bryce sphere, and render the result in Bryce. Poser objs will import into Bryce4 just fine.
Lovely Lady posted Fri, 22 March 2002 at 3:32 PM
For a quick sphere that is not that heavy in polys you can do one in UV mapper. Under file menu its is new object and you can set the dimesions.
LeBurns posted Fri, 22 March 2002 at 4:12 PM
Wow thanks for all the help. I'm uploading the image I was working on now in the Poser gallery.
