Subject: Promblem using MorphMaster, but might apply to any modeling prog
cyber-organic opened this issue on Mar 26, 2002 ยท 3 posts
cyber-organic posted Tue, 26 March 2002 at 12:12 PM
I'm trying to create a head morph using MorphMaster. It seems like it's going as it should, but when I import it into Poser and turn the dial, my character's head moves up and to the left. I've tried it twice, making sure that I didn't do something weird, but it's doing the same thing. Surely there has to be a simple reason for this that is easily remedied, but for now I'm stumped. Thanks in advance for your help.
Crescent posted Tue, 26 March 2002 at 1:25 PM
Sounds like the entire head somehow moved when you did the morph. The object has to stay exactly where it is except for the part that is being changed.
Netherworks posted Tue, 26 March 2002 at 1:34 PM
Hmm... When you export the head out of poser as a morph target, make sure all the dials are set at zero. Check body/neck dials too to make sure there aren't any JCMs fouling you up (as with Stephanie).
