mada opened this issue on Mar 27, 2002 ยท 21 posts
mada posted Wed, 27 March 2002 at 4:03 AM
Thanks Mada
...faith, trust and pixiedust
mada posted Wed, 27 March 2002 at 4:04 AM
Staale posted Wed, 27 March 2002 at 5:04 AM
Poser uses some pixels outside of the template so the pixels showing might be placed just above the transmap.
mada posted Wed, 27 March 2002 at 5:32 AM
Sue88 posted Wed, 27 March 2002 at 7:07 AM
Did you zoom in close to see if maybe there's a tiny little line in the transparency map? Is this the "UpperEyebrows"? How about the "Eyebrows"? Could there be a line there in the transmap? To me it seems like it's the edge of the eyebrow area showing for some reason.
cyber-organic posted Wed, 27 March 2002 at 7:25 AM
Like Sue said, my only guess is that maybe you're not applying the right transmap to both sets of eyebrows, upper and lower. Or maybe even that you've changed the transmap at some point but don't have the most recent transmap loaded into Poser??? Grasping at straws here.
bushi posted Wed, 27 March 2002 at 10:53 AM
Hmmm ... looks like the dial to hide the eyebrow might be a bit off.
ElectricAardvark posted Wed, 27 March 2002 at 11:39 AM
Hiram posted Wed, 27 March 2002 at 2:20 PM
If you examine the lower edge iof the eyebrow directly under the "anomaly" you will see that the anomaly is a repeat of that lower edge. It's like someone rubber-stamped that lower edge of the eyebrow to a position above it. What would cause that aside from being on the texture somewhere, I have no idea. Weird.
ElectricAardvark posted Wed, 27 March 2002 at 2:53 PM
You can also see a distinct stright edge on the top part of the brow just below the anomolly. Looks almost like it's trying to vertically tile it. If you send me the trans map I can probably get a better understanding as to what is causing it.
mada posted Wed, 27 March 2002 at 3:47 PM
Thanks, will be in contact. Mada
ElectricAardvark posted Wed, 27 March 2002 at 5:44 PM
mada posted Wed, 27 March 2002 at 6:28 PM
I'll have to play around tonight, thank you very much for your reply. :) I'll let you know how it comes out.
mada posted Wed, 27 March 2002 at 8:48 PM
That did it thank you, I had the transparency map loaded into the eyebrow section as well. That's what happens when you work late at night. :)
Sue88 posted Wed, 27 March 2002 at 9:14 PM
Okay, now I'm confused. This evening I was working on an eyebrow transmap for Stephanie myself, and I ran into the same problem. It seems that if I have a transmap for both the UpperEyebrows and the Eyebrows, there is that line above the right eyebrow. If I don't have a transmap for the Eyebrows (only for the Upper Eyebrows), there's no problem, no line. But we should be able to use a transmap for the Eyebrows, too - that's what helps the eyebrow have dimensions to it. And this problem does not happen with Mike, only with Stephanie. Could this be a problem with Stephanie's mapping? Or am I missing something? But how come it does not happen with Mike?
mada posted Wed, 27 March 2002 at 9:38 PM
That is what I thought too, which is why I had the transmap loaded into the eyebrows as well. I haven't tried the maps for Mike on Steph yet, will give that a go tonight and see if the same thing happens. Mada
Sue88 posted Thu, 28 March 2002 at 8:37 AM
Well, I've tried several things and the result is always the same. I think there's a problem with Stephanie's right Eyebrow map. I wonder if anybody else besides us has had this problem?
ElectricAardvark posted Thu, 28 March 2002 at 10:40 AM
Sue88: I found the problem with Mada's transmap, there isn't anythinfg wrong with the geometry. If you like I could look at yours and try to figure it out.
Sue88 posted Thu, 28 March 2002 at 10:49 AM
ElectricAardvark, Thank you. :) I'll get the map together and send it to you as soon as I can. (I'm just about to leave somewhere so I'll have to do it later.) I appreciate your offer. :)
Sue88 posted Thu, 28 March 2002 at 8:02 PM
ElectricAardvark, I didn't want to send you a crappy transmap so I worked on it a little more (yesterday I just did a very rough thing) and I actually managed to solve the problem. It had to do with the positioning of the Eyebrow transmap. But I do appreciate your kind offer and I thank you. :)
ElectricAardvark posted Thu, 28 March 2002 at 10:31 PM
any time
