Subject: Posette Clothing to fit Vicki....Yeah, I know....
JBroneske opened this issue on Mar 28, 2002 ยท 4 posts
JBroneske posted Thu, 28 March 2002 at 5:27 PM
I know that Posette's clothing doesn't fit Vicki because of differences in polygons.....BUT....has anyone had any luck in exporting Vicki for use as a reference and then exporting a Posette clothing object into a modeler and messing around to make it fit Vicki? I'm sure someone has tried this...if so, how did it work?
I tried doing this in Poser and had moderate success, but it was a bit of a pain to get it just right.
Just thinking.....
Joan
Little_Dragon posted Thu, 28 March 2002 at 10:31 PM
I suppose you could give the clothing the same joint parameters as Vicki, then run it through the Tailor utility. Also just thinking ....
JBroneske posted Fri, 29 March 2002 at 1:12 AM
Hmm, interesting.... and how would one give it the same joint parameters? I'm pretty new to Poser and not familiar with joint parameters, other than hearing the term bandied about on the forum.
Joan
FyreSpiryt posted Fri, 29 March 2002 at 5:38 AM
Well, if someone will help me get channels for 4 more body parts (she says shamelessly), I could finish up the Quick Conform pose file to set them in, oh, probably an hour or two.
