Forum: Poser Technical
Subject: Create a cr2 file---how?
madriver opened this issue on Apr 02, 2002 ยท 3 posts
madriver posted Tue, 02 April 2002 at 7:19 PM
Making a new figure with an original map. How do I make it so that I can sell it in the store? Does ProPack output cr2 files or do I have to use cr2edit to accomplish this? thanks!
doozy posted Tue, 02 April 2002 at 7:52 PM
When you save it into the figure menu, Poser creates a CR2.
Ericroy posted Thu, 04 April 2002 at 10:46 AM
To create a CR2 file, select the figure in the main window. Then select a sub-directory under Figures. Click the + and give the figure a name. With ProPack, to save a CR2 file, be sure that file compression is turned off before saving to the figure library. Otherwise, it will be saved as CRZ. To turn file compression off, go to Edit>General Preferences and uncheck the Save Compressed Files box. I hope this helps, Ericroy
