Subject: Fix for BAT Lab preview image problem
gyusaku opened this issue on Apr 03, 2002 ยท 3 posts
gyusaku posted Wed, 03 April 2002 at 2:55 PM
This may have been solved a long time ago and I missed it, but it's still in the ReadMe files that the preview images on the freebies from BAT Lab will not work on a Mac so I thought that I'd post the fix I came up with. This fix involves ResEdit so it's requires care. Drag the .cr2 file of the freebie onto the ResEdit icon. Grab a different .cr2 (one that you know has a preview image) and drop it onto ResEdit. Now goto ResEdit and select the file that has the preview image. Double click on the PICT Resource (looks like a little house with a tree I think...it also should be the only one there), and select the picture. Now copy that picture and select the BAT Lab file. Double click the PICT Resource and hit paste. ResEdit will warn you that there is already a resource with that ID number and ask if you want to replace it...unless you want to loose the icon CLICK "NO"! Next select Create New Resource and a new box titled 129 should be created. Double click on that and paste in the picture. Now close everything WITHOUT SAVING. And thats it. If you drag the .cr2 onto ResEdit and open the PICT Resource you should see the correct preview image labeled 128. Now placing it in the proper folder should give the proper icon in poser. There is probably an easier way, but I was just fiddling around and came up with this. I hope it's useful to someone. -gyusaku
PabloS posted Wed, 03 April 2002 at 5:27 PM
Whew! Glad I have a PC.
gyusaku posted Thu, 04 April 2002 at 6:44 AM
Now now, PCs have their own problems...such as the operating system ;p.
