TygerCub opened this issue on Apr 06, 2002 ยท 4 posts
TygerCub posted Sat, 06 April 2002 at 8:01 AM
How in the world do you do it??? What did I do wrong in the following steps? 1) Open object in UVMapper; 2) move and change the various body parts around as needed; 3) save new texture map; 4) save object, over-writting the original object, which means it's the same name, in the same folders; 5) open Poser and insert character; 6) apply texture from new texture map. And I get a muddled mess. The new mapping did not take. Obviously, I'm missing some key, vital step... Was I not holding my tongue the right way? Did I put my right foot forward when I should have used my left foot?? Please! Would someone explain where I went wrong????
Steve Cox posted Sat, 06 April 2002 at 8:16 AM
You need to delete the .rsr file that's in the same directory as the .obj file you remapped. Poser uses this to speed up loading times - once you delete it, Poser will recreate it from the new .obj file. HTH, Steve
geep posted Sat, 06 April 2002 at 8:25 AM
There ya go! You have heard from THE expert!!! .. and in only 15 minutes! Now ... where else can you get service like that? ;=]
cheers,
dr geep ... :o]
edited 10/5/2019
TygerCub posted Sat, 06 April 2002 at 8:33 AM
Oh ssswwweeeettt! thanks SO much!
