Forum: Poser Technical
Subject: Hard drive space shrinking/delete some characters and/or stuff?
tree opened this issue on Apr 09, 2002 ยท 4 posts
tree posted Tue, 09 April 2002 at 5:12 PM
To free up some space on my 4G hard drive I am thinking of removing some of the Poser folk I don't use, which is most of them. (P4 man, P4 woman, etc.) Can I do this, and just leave Michael 2.0 and Victoria 2.0, without seriously messing up the program? Any help will put you on my "new best friend" list. Thanks to you all. TREE...a comedian who can't afford a bigger hard drive but won't stop adding space-sucking apps.
SAMS3D posted Tue, 09 April 2002 at 5:56 PM
You know that is a great idea that I wish I knew also...we will wait for the wise people to help us out on this....the only thing I can think of is if you do delete some things that are used by others then you are out of luck. I would like to move some things and see if it damages the characters I use most.
Jaager posted Tue, 09 April 2002 at 6:40 PM
First, set your preferred state to have no figures on stage.
and make sure you open to preferred state and use previous state. if you erase the P2 guy before you ever open Poser the first time after a fresh install, you may get the "out of memory" death notice.
If you have or wish to use NO stock characters or props I get by with the following
in Geometries:
deform
lights
props
in Textures:
Ground Default Texture.tif
in Libraries:
keep what you use
What ever Library files that you do use, you need their geometries and textures.
But if you use no Poser stock characters, props or hair
everything seems to work with just the above.
To say it another way:
If you must install a clean version of Poser 4 after a crash.
You only use 3rd party characters, clothing and props and you have their zips and exe's in backup.
What should I not delete if I do not wish to have problems with Poser's normal functions and requirements?
tree posted Wed, 10 April 2002 at 10:50 AM
Thanks Jaager. I tried what you recommended, on another machine of course, and it seemed to work with no problems. If anything comes up later, I will post it ASAP. Thanks again.
