billy-home opened this issue on Apr 11, 2002 ยท 5 posts
billy-home posted Thu, 11 April 2002 at 2:03 PM
bloodsong posted Thu, 11 April 2002 at 4:28 PM
heyas; you want to make the sleeve of the piston a child of the body, and the bar of the piston a child of the lower leg. make sure they stick out at right angles (along the x-axis), make sure you have the proper rotation ordres (xyz), and then tell the piston sleeve and the piston rod to "point at" each other. that should work fairly well. make sure your rod is long enough so it doesn't fall out of the sleeve when you extend the leg.
Lemurtek posted Thu, 11 April 2002 at 7:33 PM
Bloodsong sayeth: >make sure your rod is long enough so it doesn't fall out of the sleeve when you extend the leg. Sage advice for all guys! :) Regards- Lemurtek
bloodsong posted Fri, 12 April 2002 at 3:42 PM
oh shut up you guys!! :)
billy-home posted Fri, 12 April 2002 at 5:31 PM
thanx, for all your "help" LOL ;-)
