AristaProductionLab opened this issue on Apr 11, 2002 ยท 7 posts
AristaProductionLab posted Thu, 11 April 2002 at 7:55 PM
CrystalWizard posted Thu, 11 April 2002 at 10:12 PM
that's not bad either.
AristaProductionLab posted Thu, 11 April 2002 at 11:44 PM
That's what I thought...Though the body to the right is cluttered you can see a fine distant tune of non distorted complexity...But I don't know which one to zoom in on first. Because !!!!Ya know how when you work in most fractal programs they are usualy the same infinite spaces over and over...whith a occasional change???Well this app is very time consuming..Because, There are infinite changes..This glob was found only afte the system of;Get ready fer this....Z-(Z5ZSIN-Z4ZSIN-ZSINZC-Z}divided into/by (5Z4ZCOS-Z4ZCOS-ZCOSZC-1}..This is actualy a realy simple equation.I think it would be coller if it had an expansion formula + expansion variables other than C....
CrystalWizard posted Fri, 12 April 2002 at 2:03 AM
AristaProductionLab posted Fri, 12 April 2002 at 2:25 AM
Hmm Looks like it would go with my trail mix...Notice the infinite orbit's you can zoom on those darn things fer ever..It's a pretty basic formula..A slight change and it would equal 1 or zero...UF has a definite form..the big white chocolate squirts indicate a interior..I hope the back room has a formula list??I have go a few tricks up my wazoo...
CrystalWizard posted Fri, 12 April 2002 at 2:33 AM
that's cause of the outside coloring formula i used. I saved your formula in a folder under your name. if you go download ultrafractal, i'll email you the folder for you to play with :)
CrystalWizard posted Fri, 12 April 2002 at 2:38 AM
