Forum: Photoshop
Subject: Rainbows in Photoshop?
Delrino opened this issue on Jan 26, 2000 ยท 4 posts
Delrino posted Wed, 26 January 2000 at 11:54 AM
Hi Friends, does anybody have a "good looking" solution for rainbows done in Photoshop?
jnmoore posted Fri, 28 January 2000 at 12:53 AM
Delrino: Try this... Make a new layer and use the ellipse marquee tool to make a circle with an arc large enough for your rainbow. Use the gradient tool in KPT to set up your colors and set to circular fill. Once you have the circle filed with the gradient, use the eraser to get rid of the parts you don't need. If you use the airbrush tool with the eraser, you can set spacing at about 50% and opacity down to about 5% to nibble away at the ends of your rainbow so it "fades" into the ground and sky (double click on the brush to bring up the dialog box for the brush). Now adjust the layer transparency until it looks "right" to you. You may have to tone down the saturation a bit, but be carefull or you'll get banding between the colors. 'Hope this works out for you... - Jim
jnmoore posted Fri, 28 January 2000 at 12:55 AM
Oh, almost forgot.. while you're seting the spacing on the brush -- also set the hardness to 0%. - Jim
Delrino posted Fri, 28 January 2000 at 8:02 AM
hello jim! thanks for this hint. i'll try it later this weekend because i'm in lack of time. to me it sound like it should be the solution i'm searching for...thank you very much again! Karsten
