Forum: Vue
Subject: little help underwater...
SAMS3D opened this issue on Apr 18, 2002 ยท 6 posts
SAMS3D posted Thu, 18 April 2002 at 1:38 PM
I know you can do it, you have to be able too....I have updated to 4.06, just so you all know....and I wanted to do an underwater scene. Is there anyway you can view the camera while it is underwater....I keep loosing where it is unless I have it selected. What am I doing wrong...? Sharen If you don't answer back before shut down...catch you on the flip side
gebe posted Thu, 18 April 2002 at 3:43 PM
Sharen, sorry, but it was already too late. Go to FILE-->OPTIONS and uncheck STOP CAMERA GOING BELOW CLIPPING PLANE. Then you can move it under the water:-) Guitta
SAMS3D posted Thu, 18 April 2002 at 4:19 PM
Oh man, that was too simple, but I can't thank you enough, I couldn't figure out what I had to do....thanks Guitta, you are great....Sharen
MickeyMo posted Sun, 21 April 2002 at 10:02 AM
Create the Water plane. Left click on the Water plane in the World Browser, and drag it below the ground plane. This will make the ground plane the "clipping plane" again. And your camera will be visible in all views. Sam
gebe posted Sun, 21 April 2002 at 11:00 AM
That's right Sam. But often you don't use a ground in underwater images and give to the ground directly a water material. Then don't forget to uncheck in the options:-) Guitta
MickeyMo posted Sun, 21 April 2002 at 7:49 PM
Thanks Guitta for sharing your Vue skills so freely with all of us. You are a blessing to this list. Sam
