Forum: Carrara
Subject: Grass Shader
ashley3d opened this issue on Apr 22, 2002 ยท 16 posts
ashley3d posted Mon, 22 April 2002 at 5:36 AM
Attached Link: http://ashley3d.home.texas.net
Does anyone have a high-rez shader for seemless grass? I want to created a realistic looking building scene. As you can see, the building has alot of space all around it that needs to be filled with grass. Thanks, Ash
bikermouse posted Mon, 22 April 2002 at 6:05 AM
That must have taken a while to set up. good work. i'd like to see some hi res grass too.(sounds memory intensive.) - o.k. BYE
Kixum posted Mon, 22 April 2002 at 9:25 AM
Have you tried any procedurals? A green shader with "noise" used in the bump channel would be a good start. I'll try to cook something up tonight. -Kix
-Kix
tkane18 posted Mon, 22 April 2002 at 11:22 AM
Attached Link: http://www.ambientlight.co.uk/downloads/textures/textures.htm
Try this site (for non-commercial use). I used their grass shaders (just jpegs) in these examples.
Kixum posted Tue, 23 April 2002 at 6:53 AM
Here's a simple procedural for grass. The lowest case mixer in the color channel allows you to change the darkness of the green very easily. -Kix
-Kix
Kixum posted Tue, 23 April 2002 at 6:56 AM
Here's how it looks.
-Kix
deuxabu posted Tue, 23 April 2002 at 9:08 AM
Try to use this map in a terrain and then scale it to the grass size you want. Maybe you will have to use several terrains as tiles to reach the results you want let me know if it works or not
nivek_ posted Tue, 23 April 2002 at 12:06 PM
I'm still using RDS and I don't know how to get a .jpg into the terain editor.
ashley3d posted Tue, 23 April 2002 at 3:49 PM
Thanks for the information. I'll give it a try and let ya'll know what happens. Ash
AzChip posted Tue, 23 April 2002 at 5:47 PM
Getting a jpg into the terrain editor isn't all that hard in RDS. Once you place a Terrain in the perspective window, the four elements: Earth window opens up. Click Edit, then above the area you normally paint in, click on the little floppy disk with an arrow pointing to the right. This allows you to import an image as height field. Default is BMP, but you can select JPG or a few other formats, too.
nivek_ posted Tue, 23 April 2002 at 6:51 PM
Thank you. I can't beleive I never noticed I could do that.
litst posted Tue, 23 April 2002 at 8:21 PM
Nice lil renders Tkane18 :) Hey, when Eric's fur plug-in will be out, realistic grass will be a snap :) !
bikermouse posted Wed, 24 April 2002 at 1:04 AM
So if i want to make my own lawn I should take a really hi res digital picture of someone's lawn, load it into my computer crop and use that as a shader / bump map? interesting ... I think I already knew that but forgot.
tkane18 posted Wed, 24 April 2002 at 11:24 AM
Thanks litst...that was the beginning of my Coffee and Donut contest entry.....but it never happened. Oh well.....maybe I'll get one in this time.
deuxabu posted Wed, 24 April 2002 at 12:56 PM
This is how a terrain looks like when you apply the map I've shown above, I don't know if it will work on ashley3d's image but it works fine for me when I need a close up. good luck, Marcelo
Kixum posted Wed, 24 April 2002 at 2:03 PM
For closeups, tkane and deux have provided excellent ideas! Has anybody tried to use a real picture of grass before? -Kix
-Kix
