Forum: Poser Technical
Subject: Problem with multiple walk paths
Paul_spg opened this issue on Apr 24, 2002 ยท 3 posts
Paul_spg posted Wed, 24 April 2002 at 12:27 PM
Hello,
I have a question on a problem I'm having with Poser 4 and multiple walk paths. I want to have 6 Poser models with 6 walk paths. I am able to set up 3 but when I add the 4th walk path to the 4th Poser model I am unable to modify the walk path (curve). When I try to select the points on the walk path to modify the curve it will not select them. I am only able to move the whole walk path object in the x,y direction.
Is there a limitation on the number of walk paths or models you can add at one time? Could it be a RAM issue or a bug? Or am I messsing something up?
My system spec is PIII 450 MHz, 128 RAM.
If anyone out there can help me out on this it would be greatly appreciated.
Thanks,
Paul
ScottA posted Wed, 24 April 2002 at 10:13 PM
Looks like it's a system issue. I loaded all four casual people figures. Clicked on them and added a walkpath to each one of them one at a time. And I could still edit the walk paths. I use a PIII 1GHz, 128meg. Ram ScottA
Paul_spg posted Thu, 25 April 2002 at 5:32 PM
Hi Scott, Thanks for trying that out and the info. I'm not sure what I'm doing wrong or is wrong with my system. I've tried rebooting, starting from a saved Poser file with the 3 working figures, but after I add the 4th figure all the walk paths kind of "lock" and I can't modify the curve. Everything else works fine with 3 or 4 figures. If anyone has any info on what the problem may be with my system please let me know. Thanks, Paul
