Forum: Carrara
Subject: 15 Minute Challenge: Beginning Formula Objects
twillis opened this issue on Apr 24, 2002 ยท 24 posts
twillis posted Wed, 24 April 2002 at 12:30 PM
Hey, I've been having fun messing with formulas, and I think I've come up with a challenge to encourage those of you who haven't messed with formulas to get your feet wet. From the Assembly room, Insert a Formula. Double click on it to go to the modeling. Erase the formula that's there, and replace it with: x=10u; y=10v; z=1; Click on the Parse button. The result will be a 10x10 plane floating 1 unit above the z-axis. Here's the challenge: Change the z line to make the resulting shape more interesting. Hint: z can be a function of u and/or v, and, since they're already defined, y and/or x.
brenthomer posted Wed, 24 April 2002 at 2:40 PM
I dont know what the heck you are talking about... You know what would be nice maybe? A complete list of numeric commands you can use..is that even in the manual? I dont remember seeing it. -brent
twillis posted Wed, 24 April 2002 at 2:59 PM
It's in Chapter 20 of my version of the manual. I'll try to print a screen shot of the formula editor when I get home today, so that what the heck I'm talking about is a bit clearer. Meanwhile, here's one to try: z=x*y;
nyar1ath0tep posted Wed, 24 April 2002 at 3:55 PM
As a beginner, I can appreciate a challenge like this. So here's the formula: x=10*(u-.5); y=10*(v-.5); z=10-(x*x+y*y)/4; Apparently u and v vary from 0 to 1 (like in UVMapping coordinates), so I had to keep it at u-.5 and v-.5 to get a full surface of revolution. It looks like x and y limit the boundaries, and z is the real equation for the surface.
twillis posted Wed, 24 April 2002 at 5:53 PM
Very cool. The "u-0.5" trick is a handy one, also multiplying that by PI, or 2PI can be useful for trigometric functions. It does appear you can mix and match a bit; u doesn't have to be the variable for x, and so on. Anyway, here is a quick screen shot of the starting (boring) formula:
twillis posted Wed, 24 April 2002 at 5:56 PM
Slightly more intersting. Very slightly.
twillis posted Wed, 24 April 2002 at 5:59 PM
OK, now we are getting somewhere. Notice the "p1" variable in the last line. That's so I can animate this sucker.
twillis posted Wed, 24 April 2002 at 6:03 PM
Heck, while were at it, how about a formula texture. Formula textures are similar to formula objects, only instead of using u and v to generate x, y and z values, you use u, v, x, y and z to generate red green blue values. floor(x) is a handy function, basically it return the next lowest interger. For example, if x=4.317, floor(x) = 4, and x-floor(x)= 0.317. I use this to keep rgb values between 0 and 1, and it's an easy way to make stripes. ceil(x) works in a similar way.
twillis posted Wed, 24 April 2002 at 6:16 PM
Whee! And this animation only has two keyframes; p1=-1 in the first frame, and p1=1 in the last. The formula does everything else.
keithw posted Wed, 24 April 2002 at 7:39 PM
Hey Terri, I tried to place the black and white checkerboard texture on your animated formula. This is what I got
nivek_ posted Wed, 24 April 2002 at 8:37 PM
I don't know what I'm doing with this formula thing but, when I type stuff in it RDS crashes. The formula is: x=cos(4PIv)cos(72PIp1u); y=1; z=1; Is this formula impossible?
nyar1ath0tep posted Thu, 25 April 2002 at 12:07 AM
I think x has to be a function of u alone and y has to be a function of v alone, so I think x=cos(4PIv)cos(72PIp1u) would cause a circular reference that would crash the software.
Kixum posted Thu, 25 April 2002 at 2:37 AM
Here's Mine
-Kix
twillis posted Thu, 25 April 2002 at 8:15 AM
Very cool, Kixum. What was the formula? That shape would make a fun alien or monster, flying toward you to absorb your soul! Well, if that's your idea of fun, anyhow. nyar1ath0tep, I'm not sure that x has to use u, and that y has to use v (I guess I need to test this more). Plus, I'm not sure how RDS differs. nivek, I think that your x definition might be ok, and that the problem is have both y and z equal to a constant; the result would be a line segment at y=1 and z=1, with the width determined by your x formula, which might not be visible, or might confuse RDS. Try making either y or z a function of u or v, like y=10u, and see if that helps. keithw, I like the "checkboard" you got. Would make for a challenging game, don't you think? I'm not sure, but I think you could make a checker board that "stuck" to the shape, by defining the regions in terms of u and v. You might try a simple 4-square, with something like: a = floor(u2); (result should be 0 or 1) b = floor(v2); (result should be 0 or 1) blue = ab; (result should be 0 or 1) I think the result would be a 4-square checker board, but you guys might want to check my math. Um, might have to add some sort of fudge factor for u and v = 1, but I'll test it when I get home today.
twillis posted Thu, 25 April 2002 at 5:14 PM
OK, nivek, I've been playing with your formula. In Carrara, you can mix and match u, v, x, y, z. Not sure about RDS. Here's one adaptation of your formula.
twillis posted Thu, 25 April 2002 at 5:17 PM
But perhaps this was what you had in mind.
twillis posted Thu, 25 April 2002 at 5:27 PM
Also, it turned out that the checkerboard formula was a bit more complicated than I thought. This should work, and let you change the values of h and i to control the how many squares across and down you have. Nivek's formula is groovy, so I used it for this example.
DotPainter123 posted Thu, 25 April 2002 at 6:35 PM
I tried some parametric functions from by calc book and still yechhh! I need to play with this some more!
keithw posted Thu, 25 April 2002 at 7:51 PM
Thanks again Terri! It works perfectly. The checkerboard now moves with the animation. I had a little trouble with the formula until I figured out that || is not two lowercase l's and that both h and i should be equal. Keith
nivek_ posted Thu, 25 April 2002 at 8:15 PM
Thanks for the help twillis. I typed in your ammended formula and ended up with a small flat shape. But it didn't crash. Is there a difference between RDS and C formula?
Kixum posted Thu, 25 April 2002 at 11:11 PM
My formula.
-Kix
keithw posted Fri, 26 April 2002 at 7:00 AM
Here is Terri's animateable checkerboard texture formula applied to an animated formula object. No more changing patterns! Here's the formula I used for the animated object. x=10*u; y=10*v; z=cos(2*PI*p2*(4*u))*cos(2*PI*p1*(4*v));
Nicholas86 posted Sat, 01 June 2002 at 6:26 PM
I will be copying the information from here to my website for a resource for others. All users names will be sited. If you have a problem with me using your formula, please email me and we could work something out. Thanks you. I hope for more assistance from those of you who have a better understanding of formula
twillis posted Sat, 01 June 2002 at 9:26 PM
You're welcome to use anything I have posted here.
