rami opened this issue on Apr 26, 2002 ยท 7 posts
rami posted Fri, 26 April 2002 at 8:21 AM
i am new to all this but i need to know is it posible to make my owne models in poser or i have to do it in other software eg truespace then svae it and open it on poser the creat the stuff i want. thanks
Jaqui posted Fri, 26 April 2002 at 8:36 AM
you can make your own stuff in poser, but it is often easier to use a different program to do so. check out the tutorials section here to see how most people make props ect.
rami posted Fri, 26 April 2002 at 8:41 AM
can u just tell me how could i do it with poser. thanks
Jaqui posted Fri, 26 April 2002 at 8:54 AM
modelling in poser...what version of poser? do you have pro-pack? if yes to latter, check the pro-pack help in poser itself, it has a fairly simple tutorial with it, that would give you the basics for said modelling.
rami posted Fri, 26 April 2002 at 8:58 AM
i got poser 4 and thanks any way ,just one more qustion how did u learn all this like by ur self or u went to a corss. thanks
Jaqui posted Fri, 26 April 2002 at 9:07 AM
I cheated, I married someone who has spent a long time learning poser (Stormrage), so I have her knoweledge to draw upon. ~g~ with poser 4 you basically squish sqares and globes into a combination until you have the appearance you want, select them all and group them together, export an obj and map it to make it texturable. you need to "cut" the mesh to make it poseable, and set up a heirarchy and joint parameters and cr2 for the prop.
c1rcle posted Fri, 26 April 2002 at 9:56 AM
it sounds so simple when you say it like that Jaqui, shame it can takes months of hard work to get something usable, I cheat as well, but I'm not as extreme as you Jaqui :) I just let someone else do all the hard work
