Subject: I am suffering
MJHCreations opened this issue on Apr 29, 2002 ยท 5 posts
MJHCreations posted Mon, 29 April 2002 at 3:13 AM
I have recently purchased Dina V and and the clothing packs, and I have noticed, if I move a certain body part, (hips, arms and neck--on Dina V)it drastically the fit of the clothing. This also happens when I attempt to rotate the model as well, making for some very frustrating posing. What if anything can be done about this. Guidance is extremely welcome and needed. Thank you
OJM posted Mon, 29 April 2002 at 4:33 AM
And how about not conforming the clothes but saving the Dyna Pose and then applying it to the clothes ? PhEn.
Marque posted Mon, 29 April 2002 at 4:53 AM
Yes but what if you want to do an animation? Marque
Strangechilde posted Mon, 29 April 2002 at 6:31 AM
I had something similar happen when using the Victoria clothes pack. Moving the figures did some most peculiar things to the clothing, and I could see the various parts of the clothes wibbling about as the figure moved... I have no idea why this is. The solution, I found, was to pose the figure without clothing, then load the clothing and conform. Kind of annoying if you're working on an animation, though, wouldn't it be?
Dragontales posted Mon, 29 April 2002 at 11:33 AM
I don't know if this is related to your problem, but I had a similar problem with Victoria as well. I put the catsuit on her and anything more than slightly bent would cause her to come thru the suit. What I finally found out was that because I scaled everything in the Y axis (I wanted her a bit shorter) that threw everything off. I rescaled her back to 100 percent, and it worked perfectly. Moral - don't scale figures in single directions. Hell, probably not in any direction. HOpe it helps. Dragontales
