Forum: Bryce
Subject: helix or spirals spring like objects
Stephen Ray opened this issue on Apr 30, 2002 ยท 3 posts
Stephen Ray posted Tue, 30 April 2002 at 9:36 PM
There was a post awhile back asking how to make helix or spirals spring like objects. Well it's really easy in Bryce. Multi replicate using values like these. offset 6-5-4 rotate 4-5-6 And you don't need to start with metaballs ( for B4 ) but you can convert to metaballs ( B5 ) or another shapes after you multi replicate, using the double arrow tool at the top left of the edit palette. You can use higher values, but if you use or plan on converting to metaballs keep the offset values close together, so the metaball will cling to each other.
Stephen Ray
