Forum: Photography
Subject: Image size guidelines.
Misha883 opened this issue on May 02, 2002 ยท 12 posts
Misha883 posted Thu, 02 May 2002 at 10:41 AM
Had a few idle moments, checked the FAQ, thought I'd ask here: What size images would folks appreciate seeing in the Gallery and in the Forum? And how much compression? I do not like to scroll pictures, so I like to limit the size to about 600 pixels vertical by 900 horizontal, (my monitor is set to 864X1152, and figure tool-bar stuff). For the Forum, I usually post smaller because it is more to illustrate than impress, and I want to keep downloads speedy. In Photoshop, my jpeg compression is set to "medium." I may increase this some for the contests, especially if B&W which are pretty small anyway. Gallery images run around 100K, and I really hesitate to post anything more than 175K. Forum images I try to hold to below 80K. I have a cable modem (!!!joy). I'm betting others have different preferences...
SueO posted Thu, 02 May 2002 at 10:51 AM
Misha, you have stated fairly reasonable guidelines, comparable to what I have to use on other image-sites. I would bet that dial-up users would prefer images not larger than 100 K. I have been setting images to 72 dpi, and 600 pixels on the longest side, and compressing to about 8 in photoshop. This gives images which do not require scrolling on a reasonable monitor, and which are virtually always under 100 K.
bevchiron posted Thu, 02 May 2002 at 11:57 AM
I think it really depends on the image, your guidelines sound ok for most things Misha but I do find really detailed images lose quite a lot if compressed or downsizwd too much. I agree about scrolling, especially side ways, I just feel like I can't see the image if I have to scroll a lot. I'm on dial up & only find it gets really slow around 300, depends how fast the site's moving. 200 is definitely ok.
elusive.chaos
"You need chaos in your soul to give birth to a dancing star...." (Nietzsche)
Michelle A. posted Thu, 02 May 2002 at 12:02 PM
Well I pretty much resize to 800x600 and under 150k....but that's just me.
I am, therefore I create.......
--- michelleamarante.com
ASalina posted Thu, 02 May 2002 at 12:03 PM
Since I've had this monitor and card setup for so long I
kinda presume that others have a similar setup, seeing as
how I always seem to be behind the hardware curve compared
to other people. I have a 21" monitor running in 1600x1200,
so those dimensions are the absolute maximum limit for my
final images. My digi-cam produces images that are 2272x1704
and after cropping I scale that image by about .5 as a
matter of course, which leaves me with an image of less than
1136x852. A little large, I guess, for smaller display
systems. I always try to go for maximum quality / minimum
jpeg compression that stays under the 500k limit.
That's for my Gallery postings. For here in the forum, I
typically reduce the dimensions by half again (568x426)
and stay under the 200k limit.
This brings up a question that I've had in the past: Would
PNG files help in preserving quality while maintaining small
file size, and will Renderosity accept this file format?
Would many people have trouble viewing this format?
PhrankPower posted Thu, 02 May 2002 at 5:51 PM
A lot of different responses. I think the Macs are different from the PC, but I believe the PCs are 640x480, 800x600, 1024x768, 1152x864 and 1280x1024. I use 1024x768, and I now post so someone at that setting wont have to scroll (allowing for the browser borders and such), although earlier I didnt. So the question is, what resolution is the most popular here? I thought 1024x768 was, but maybe Im wrong.
JordyArt posted Thu, 02 May 2002 at 6:18 PM
Well, from previous posts of this nature I think we found a few of us (myself included) are still stuck on 800 x 600 for now.... When I post an image I usually make it 600 pixels wide, and with a Photoshop compression of 9 that seems to work out about right for up/downloading speeds on my cable modem also. I hate big images, you really can't appreciate them at all when you have to scroll to see them, but no doubt I'll fall into line when I can afford a bigger monitor! (",)
bsteph2069 posted Thu, 02 May 2002 at 6:52 PM
I'm in the same boat at Joardy. Misha as I recall you current image size is alright. I think I often go above the 100K limit. BUT I too am using dial up connection. HOWEVER my modem is a ole 33.6. Since I'm comfortable with the download time and I thought my modem was the slowest around here. I don't feel bad about 100K size. I don't mind scroling much although ( Sorry Alpha ) some stuff certain people post ( cough, cough, aplha ) is a tad big and always requires scroling. It's not a problem however, but I have to save and look at the picture in some art program to see it all at onece which I believe is the way it should be seen. Let's face it scrolling images from the top down and then from the left to the right biases our responce to a image. OR am I alone in my feelings of this. Bsteph
PunkClown posted Thu, 02 May 2002 at 8:04 PM
I'm sort of in Misha's ball park, I rarely post anything over 180k in the galleries, but occasionally I just have to, (well I don't, but like Bev I dislike too much loss) I hhave a 17" Monitor (read 15" screen real estate) and my settings are at 1024 x 768, so I apoligise to anybody else who has smaller screens & seettings like Jordy, if they have to scroll. Forum postings I try to keep around the 100k or lower mark, but as usual there are exceptions...I have a relatively slow dial-up, so the load times for images are probably as slow as anyone can get, but I don't mind ususally, because most images are usually worth waiting for. The only thing I will say is that iit cuts down onthe available time I have for browsing the galleries, visiting the forum etc!
bevchiron posted Thu, 02 May 2002 at 11:50 PM
I'm on 800x600 (Mac is the same as PC I think) & I seem to remember when this discussion came up a couple of times before most people are on the same. I think I'll try a different set up just to see what it's like...
elusive.chaos
dreamsosweet posted Fri, 03 May 2002 at 1:27 AM
I'm on 800x600, mostly cos anytime I try anything bigger, I get headaches trying to read the nav bars and the text, maybe I'm doing something wrong....
JordyArt posted Fri, 03 May 2002 at 5:58 PM
Though my screen is 800x600, I'm really not bothered about filesize - even though I'm on a dialup I only pay a fixed amount each month, so time doesn't bother me, and I just view bigger images in ACDSee. Others I think still pay per minute, though - I'm pretty sure Gunsan has mentioned this before. (",)
