bh404 opened this issue on May 02, 2002 ยท 7 posts
bh404 posted Thu, 02 May 2002 at 5:22 PM
pixelicious posted Thu, 02 May 2002 at 5:32 PM
i don't know what to tell you. i never use rds, but your image is lookin' good. you had better be preparing this for the contest. in fact, no one should be allowed to work on anything right now but the contest. : )
-pix
Kixum posted Thu, 02 May 2002 at 7:06 PM
I didn't know you could do that in RDS. I've had many reasons to want to exclusively do this kind of thing in C but have never discovered a way to make it work. -Kix
-Kix
ewinemiller posted Thu, 02 May 2002 at 7:50 PM
There is no way to do 3D Aura by object. Your best bet is render aura and no aura versions and do a little mixing and matching of parts in your favorite 2D app. Good Luck, Eric Winemiller Digital Carvers Guild Freeware and commercial 3D extensions http://digitalcarversguild.com
Eric Winemiller
Carrara and LightWave
plug-ins
Julian_Boolean posted Thu, 02 May 2002 at 9:07 PM
The above illustration shows a glowing sphere partially obscured by a rectangle, but when the rectangle's transparency is set to 100% ~~~ viola ~~~ the object is visible, but the aura is still blocked.
Hope that helps.
Jim Z. a.k.a. Julian Boolean
bh404 posted Fri, 03 May 2002 at 3:07 AM
Yeah I was just about to mention that when I noticed the storefront interiors lacking Aura. Thanks for the tip though. I would've never known that it was an actual (not to mention helpful) bug.
vhigh posted Fri, 03 May 2002 at 2:50 PM
Have you tried the 3D option for 3D Aura? Or the brightness slider on the glow channel or use a darker color for your glow?
