genetic opened this issue on May 06, 2002 ยท 4 posts
genetic posted Mon, 06 May 2002 at 1:29 PM
Hi, kinda need some help here, the window with my poser character in it, is stuck up at the top right hand corner, and I can't move it back to the center of the screen. I've seen some ppl post similar problems but i don't know how they fixed it, or even if they fixed it. If anybody knows how to fix this problem or has any input into it, please let me know ASAP, cuz i'm kinda stuck in a bind here. Thanks all.
SAMS3D posted Mon, 06 May 2002 at 1:56 PM
What you want to do is put poser back to the factory state and then your window will come back down....I am not sure what catagory it is in, check File and then preferences....and you can get it back from there. Sharen
genetic posted Mon, 06 May 2002 at 2:46 PM
WOOOOOOOOOOOOOOOO HOOOOOOOOOOOOOOOOOOOOOOOOO! Thanx. That Works
wipe posted Mon, 06 May 2002 at 3:29 PM
To stop it happening again(well correct it quickly), set up the interface as you like it and then click on an empty UI dot. Then if it happens again, simply select UI dots and click on the one you saved and the window et al will return to your preferred state.
