polld opened this issue on May 07, 2002 ยท 11 posts
polld posted Tue, 07 May 2002 at 4:10 PM
Hi and Help, please, New to poser - so forgive me.....................but when I try to apply a texture to a model it doesn't fit properly, I downloaded one and it's as if it needs twisting to fit or something. Ive looked through manual - can't see anything Help, please! Cheers Poll
SAMS3D posted Tue, 07 May 2002 at 4:23 PM
Sometimes textures have to be applied by individual parts, load your figure, then go to the materials library, find the body part that has the texture applied to it, find your texture and load it, do that to each body part. Sharen
SAMS3D posted Tue, 07 May 2002 at 4:24 PM
If you need more specific instructions, email me and I will walk you through it....Sharen SC@sams3d.com
Sue88 posted Tue, 07 May 2002 at 4:24 PM
Is the texture specifically for the model? The objects have their own uv maps and the textures must fit these. Could you post an image so we could see the problem? Sue
Sue88 posted Tue, 07 May 2002 at 4:26 PM
It could also be what Sharen said. :)
polld posted Tue, 07 May 2002 at 4:39 PM
Tashar59 posted Tue, 07 May 2002 at 5:21 PM
Go to materials and check the box that says textures material aplies to entire figure. This is the best way for P4 figures. If you still have a problem, then the texture your using is not for that figure. Hope this helps. Tashar 59
beav1 posted Tue, 07 May 2002 at 5:56 PM
Any chance you're trying to put a P3 texture on a P4 figure, or the other way "round? I used to mess that up all the time. Beav
Sue88 posted Tue, 07 May 2002 at 6:10 PM
You're using the wrong texture for the figure. When you load the nude woman, her texture is already loaded in the Materials window, so you don't have to load it from somewhere else. If you want to use a different texture, you can find many nice ones (look here at Renderosity in the Free Stuff area). Then, after you downloaded and unzipped that texture, you can put it on Posette.
Sue88 posted Tue, 07 May 2002 at 6:21 PM
It's Posette, right? If you look for free textures for Posette, make sure that the textures you download are for her and not for somebody else like Vicki or Stephanie. :)
polld posted Wed, 08 May 2002 at 4:29 AM
Ahhh, Now I see - Being new I thought (and now I think, I understand) that textures would fit all models - but that's not the way it works...................... cheers all, Poll (mental note to self: think about stuff)
