Subject: Camera Tip for the "Portrait" Poser Challenge
Lisas_Botanicals opened this issue on May 07, 2002 ยท 8 posts
Lisas_Botanicals posted Tue, 07 May 2002 at 8:32 PM
Attached Link: http://www.renderosity.com/messages.ez?ForumID=12356&Form.ShowMessage=692661
When composing a portrait render in Poser one way to get a nice photographics style is to use the "Face Camera" and set the Camera's "Focal" dial somewhere between 100mm and 150mm. Some people will set the Focal dial as high as 350mm.
To see the differences in the Camera Focal settings and how they would enhance a Portrait Render, have a peek at
http://www.buckalew.net/lisa/tutorials/camerafocusing.html
There are several photographers that frequent the forums here that perhaps can add to this thread and give you all a technical point of view and the general rules to follow when doing a portrait.
HTH!
Lisa
smerc posted Tue, 07 May 2002 at 8:44 PM
Thanks for the tip. The pictures really help illustrate how different focal lengths affect the portrait. smerc
Bongo posted Tue, 07 May 2002 at 9:41 PM
Portraight photographers like the longer lenses because: 1. gives a nice working distance to the subject, camera not too close or too far to make subject comfortable. 2. less depth of field makes the background softer, drawing attention to subject. 3. big features, like noses, are flatten somewhat.
Dolphin posted Wed, 08 May 2002 at 4:02 AM
holy hairy mackarellis!!.. it's amazing how much difference these little things can make huh?.. the focal length of the camera is a feature I've somewhat looked over in the past. thanks for bringing it to my attention, I'll be using (or abusing - I'm not really that goodL) it with careul consideration from now on :) Thanks again Dolphy.. ;D
jimjur posted Wed, 08 May 2002 at 10:56 AM
I used 110 mm for this portrait
Bongo posted Wed, 08 May 2002 at 7:51 PM
nice texture map too
Cada posted Thu, 09 May 2002 at 3:44 AM
Speaking for myself, I think when working on a portrait picture the important factors to realise are that the main focal point is the subject or character under observation. Therefore the three most important fundamental elements of any image are composition, lighting and texture. Images containing a large scene can lead an observer to key areas within the scene through linear perspective alignment. While working on close-up work I concentrate more on expression and detail. A smile, frown, raised eyebrow or anything that breaks the stiff lifeless pose. The idea is to breathe life into the subject. When working on a new character I often work with a mirror next to my PC and find myself pulling various faces and trying to duplicate the expressions. This exercise gives you a good insight into basic facial expressions. Experimentation is a good route to a good image. Practice, patience and time is all thats needed, above all remember that the image is for you! .. It doesnt matter if the image does not get the feedback you anticipated, just stick at it and remain positive. Good luck! Cada
Bongo posted Thu, 09 May 2002 at 8:45 AM
good points. I think most Poser portraits have problems with lighting and symetry. Look at the sudlty of shadow in the portrait above and the differences in left and right halves of the face. These are details we might gloss over in a medium shot, but are the bread and butter in the portrait.
